application snapshot restore
Restore an application or protection group to a snapshot.
This command restores a Snapshot that belongs to a specified protection-group in a given application. Every application instance also acts as a protection-group and can be treated as one.
-vserver <vserver name>- Vserver-
This specifies the Vserver that contains the application on which the Snapshot is to be restored.
-application <text>- Application-
This specifies the name of the application that we want to restore from a Snapshot.
[-protection-group <text>]- Protection Group-
This specifies the name of the protection-group where a Snapshot is to be restored. This field is optional, and if not specified, the application itself will be treated as the protection-group.
-snapshot <snapshot name>- Snapshot-
This specifies the name of the Snapshot that is to be restored.
The following example restores a Snapshot named snap1 on a application named myapp1 on a vserver named vs of a protection-group called myapp1.
cluster1::> application snapshot restore -vserver vs -application myapp1 -protection-group myapp1 -snapshot snap1
