storage bridge show
Display bridge information
The storage bridge show command displays information about all the storage bridges in the MetroCluster configuration. The bridges must have been previously added for monitoring using the storage bridge add command. If no parameters are specified, the default command displays the following information about the storage bridges:
Bridge
Symbolic Name
Vendor
Model
Bridge WWN
Is Monitored
Monitor Status
To display detailed profile information about a single storage bridge, use the -name parameter.
[-fields <fieldname>,…] -
Displays the specified fields for all the storage bridges, in column style output.
[-connectivity ] -
Displays the following details about the connectivity from different entities to the storage bridge:
Node
Initiator
Initiator Side Switch Port
Target Side Switch Port
Target Port WWN
Target Port Number
[-cooling ] -
Displays the following details about the chassis temperature sensor(s) on the storage bridge:
Sensor Name
Reading in degree Celsius ©
Fan operational status
Minimum Safe Operating Temperature in degree Celsius ©
Maximum Safe Operating Temperature in degree Celsius ©
Sensor Status
[-error ] -
Displays the errors related to the storage bridge.
[-ports ] -
Displays the following details about the storage bridge FC ports:
Port number
Port administrative status
Port operational status
Port operating mode
Port negotiated speed
Peer world wide name
Displays the following details about the storage bridge SAS ports:
Port number
Port negotiated data rate
Port data rate capability
Port PHY1 operational status
Port PHY2 operational status
Port PHY3 operational status
Port PHY4 operational status
[-power ] -
Displays the status of the replaceable power supplies for the FibreBridge 7500 only:
Power supply name
Power supply status
[-sfp ] -
Displays the following details about the storage bridge FC ports Small Form-factor Pluggable (SFP):
Port number
SFP vendor
SFP serial number
SFP part number
SFP speed capability
Displays the following details about the storage bridge SAS ports Quad Small Form-factor Pluggable (QSFP):
Port number
QSFP vendor
QSFP serial number
QSFP type
QSFP part number
Displays the following details about the storage bridge SAS ports Mini-SAS HD:
Port number
Mini-SAS HD vendor
Mini-SAS HD serial number
Mini-SAS HD type
Mini-SAS HD part number
[-stats ] -
Port number
Port operational mode
Port link failure count
Port synchronization loss count
Port CRC error count
Port received word count (Rx)
Port transmitted word count (Tx)
Port number
PHY port number
Port speed capability
Port invalid DWORD count
Port disparity error count
Port PHY reset count
Port link changed count
[-instance ]} -
Displays expanded information about all the storage bridges in the system. If a storage bridge is specified, then this parameter displays the same detailed information for the storage bridge you specify as does the -name parameter.
[-name <text>]- Bridge Name-
Displays information only about the storage bridges that match the name you specify.
[-wwn <text>]- Bridge World Wide Name-
Displays information only about the storage bridges that match the bridge wwn you specify.
[-model <text>]- Bridge Model-
Displays information only about the storage bridges that match the bridge model you specify.
[-vendor {unknown|Atto}]- Bridge Vendor-
Displays information only about the storage bridges that match the bridge vendor you specify.
[-fw-version <text>]- Bridge Firmware Version-
Displays information only about the storage bridges that match the bridge firmware version you specify.
[-serial-number <text>]- Bridge Serial Number-
Displays information only about the storage bridges that match the bridge serial number you specify.
[-address <IP Address>]- Bridge IP Address-
Displays information only about the storage bridges that match the bridge IP address you specify.
[-is-monitoring-enabled {true|false}]- Is Monitoring Enabled for Bridge?-
Displays information only about the storage bridges that match the bridge monitoring value you specify.
[-status {unknown|ok|error}]- Bridge Status-
Displays information only about the storage bridges that match the bridge monitoring status you specify.
[-profile-data-last-successful-refresh-timestamp {MM/DD/YYYY HH:MM:SS [{+|-}hh:mm]}]- Bridge Profile Data Last Successful Refresh Timestamp-
Displays information only about the storage bridges that match the profile data last successful refresh timestamp you specify.
[-symbolic-name <text>]- Bridge Symbolic Name-
Displays information only about the storage bridges that match the symbolic name you specify.
[-snmp-community <text>]- SNMP Community Set on the Bridge-
Displays information only about the storage bridges that match the bridge SNMP community you specify.
[-error-text-list <text>,…]- Bridge Error Description List-
Displays information only about the storage bridges that have the errors you specify.
[-temp-sensor-name <text>]- Temperature Sensor Name-
Displays information only about the storage bridges that have the temperature sensor with the name you specify.
[-min-safe-oper-temp <integer>]- Minimum Safe Operating Temperature in Degree Celsius-
Displays information only about the storage bridges that have the temperature sensor with the minimum safe operating temperature you specify.
[-max-safe-oper-temp <integer>]- Maximum Safe Operating Temperature in Degree Celsius-
Displays information only about the storage bridges that have the temperature sensor with the maximum safe operating temperature you specify.
[-temp-reading <integer>]- Chassis Temperature Sensor Reading in Degree Celsius-
Displays information only about the storage bridges that have the temperature sensors with the reading you specify.
[-temp-sensor-status {normal|warning|critical}]- Chassis Temperature Sensor Status-
Displays information only about the storage bridges that have the temperature sensor with the status you specify.
[-temp-data-last-successful-refresh-timestamp {MM/DD/YYYY HH:MM:SS [{+|-}hh:mm]}]- Bridge Chassis Temperature Data Last Successful Refresh Timestamp-
Displays information only about the storage bridges that match the temperature sensor data last successful refresh timestamp you specify.
[-fc-port-index-list <integer>,…]- Bridge FC Port Index List-
Displays information only about the storage bridges that have the ports with the indexes you specify.
[-fc-port-oper-state-list {unknown|online|offline}]- Bridge FC Port Operational State List-
Displays information only about the storage bridges that have the ports with the operational states you specify.
[-fc-port-admin-state-list {unknown|disabled|enabled}]- Bridge FC Port Admin State List-
Displays information only about the storage bridges that have the ports with the administrative states you specify.
[-fc-port-negotiated-data-rate-list {unknown|2|4|8|16}]- Bridge FC Port Negotiated Data Rate List-
Displays information only about the storage bridges that have the ports with the negotiated data rates you specify.
[-fc-port-negotiated-conn-mode-list {unknown|loop|n-port}]- Bridge FC Port Negotiated Connection Mode List-
Displays information only about the storage bridges that have the ports with the negotiated connection modes you specify.
[-fc-port-wwn-list <text>,…]- Bridge FC Port WWN List-
Displays information only about the storage bridges that have the ports with the world wide names you specify.
[-fc-port-data-last-successful-refresh-timestamp {MM/DD/YYYY HH:MM:SS [{+|-}hh:mm]}]- Bridge FC Port Data Last Successful Refresh Timestamp-
Displays information only about the storage bridges that match the FC ports data last successful refresh timestamp you specify.
[-fc-port-stats-index-list <integer>,…]- Bridge FC Port Index List-
[-fc-port-tx-words-list <integer>,…]- Bridge FC Port Transmitted Word Count List-
Displays information only about the storage bridges that have the ports with the number of transmitted words you specify.
[-fc-port-rx-words-list <integer>,…]- Bridge FC Port Received Word Count List-
Displays information only about the storage bridges that have the ports with the number of received words you specify.
[-fc-port-link-failures-list <integer>,…]- Bridge FC Port Link Failure Count List-
Displays information only about the storage bridges that have the ports with the number of link failures you specify.
[-fc-port-sync-losses-list <integer>,…]- Bridge FC Port Sync Loss Count List-
Displays information only about the storage bridges that have the ports with the number of synchronization losses you specify.
[-fc-port-invalid-crc-list <integer>,…]- Bridge FC Port Invalid CRC Count List-
Displays information only about the storage bridges that have the ports with the number of invalid CRCs you specify.
[-fc-port-stats-data-last-successful-refresh-timestamp {MM/DD/YYYY HH:MM:SS [{+|-}hh:mm]}]- Bridge FC Port Stats Last Successful Refresh Timestamp-
Displays information only about the storage bridges that match the fc port stats data last successful refresh timestamp you specify.
[-sas-port-index-list <integer>,…]- Bridge SAS Port Index List-
Displays information only about the storage bridges that have the SAS ports with the indexes you specify.
[-sas-port-oper-state-list {unknown|online|offline|degraded}]- Bridge SAS Port Operational State List-
Displays information only about the storage bridges that have the SAS ports with the operational states you specify.
[-sas-port-phy1-oper-state-list {unknown|online|offline}]- Bridge SAS Port PHY1 Operational State List-
Displays information only about the storage bridges that have the SAS ports with the PHY1 operational states you specify.
[-sas-port-phy2-oper-state-list {unknown|online|offline}]- Bridge SAS Port PHY2 Operational State List-
Displays information only about the storage bridges that have the SAS ports with the PHY2 operational states you specify.
[-sas-port-phy3-oper-state-list {unknown|online|offline}]- Bridge SAS Port PHY3 Operational State List-
Displays information only about the storage bridges that have the SAS ports with the PHY3 operational states you specify.
[-sas-port-phy4-oper-state-list {unknown|online|offline}]- Bridge SAS Port PHY4 Operational State List-
Displays information only about the storage bridges that have the SAS ports with the PHY4 operational states you specify.
[-sas-port-admin-state-list {unknown|disabled|enabled}]- Bridge SAS Port Administrative State List-
Displays information only about the storage bridges that have the SAS ports with the administrative states you specify.
[-sas-port-data-rate-capability-list {unknown|1.5Gbps|3Gbps|6Gbps|12Gbps}]- Bridge SAS Port Data Rate Capability List-
Displays information only about the storage bridges that have the SAS ports with the data rate capabilities you specify.
[-sas-port-negotiated-data-rate-list {unknown|1.5Gbps|3Gbps|6Gbps|12Gbps}]- Bridge SAS Port Negotiated Data Rate List-
Displays information only about the storage bridges that have the SAS ports with the negotiated data rates you specify.
[-sas-port-wwn-list <text>,…]- Bridge SAS Port WWN List-
Displays information only about the storage bridges that have the SAS ports with the world wide names you specify.
[-sas-port-data-last-successful-refresh-timestamp {MM/DD/YYYY HH:MM:SS [{+|-}hh:mm]}]- Bridge SAS Port DB Data Last Successful Refresh Timestamp-
Displays information only about the storage bridges that match the SAS ports data last successful refresh timestamp you specify.
[-sas-port-stats-phy-index-list <integer>,…]- Bridge SAS Port PHY Index List-
Displays information only about the storage bridges that have the SAS ports with the PHY indexes you specify.
[-sas-port-link-changed-list <integer>,…]- Bridge SAS Port Link Changed Count List-
Displays information only about the storage bridges that have the SAS ports with the link changed count you specify.
[-sas-port-invalid-crc-list <integer>,…]- Bridge SAS Port Invalid CRC Count List-
Displays information only about the storage bridges that have the SAS ports with the invalid CRCs you specify.
[-sas-port-phy-reset-list <integer>,…]- Bridge SAS Port PHY Reset Count List-
Displays information only about the storage bridges that have the SAS ports with the PHY reset count you specify.
[-sas-port-sync-losses-list <integer>,…]- Bridge SAS Port Sync Loss Count List-
Displays information only about the storage bridges that have the SAS ports with the synchronization losses you specify.
[-sas-port-disparity-count-list <integer>,…]- Bridge SAS Port Disparity Count List-
Displays information only about the storage bridges that have the SAS ports with the disparity count you specify.
[-sas-port-invalid-dword-list <integer>,…]- Bridge SAS Port Invalid DWORD Count List-
Displays information only about the storage bridges that have the SAS ports with the invalid DWORD count you specify.
[-sas-port-stats-index-list <integer>,…]- Bridge SAS Port Index List-
[-sas-port-stats-data-rate-capability-list {unknown|1.5Gbps|3Gbps|6Gbps|12Gbps}]- Bridge SAS Port Data Rate Capability List-
[-sas-port-stats-negotiated-data-rate-list {unknown|1.5Gbps|3Gbps|6Gbps|12Gbps}]- Bridge SAS Port Negotiated Data Rate List-
[-sas-port-stats-data-last-successful-refresh-timestamp {MM/DD/YYYY HH:MM:SS [{+|-}hh:mm]}]- Bridge SAS Port Statistics Data Last Successful Refresh Timestamp-
Displays information only about the storage bridges that match the SAS port stats data last successful refresh timestamp you specify.
[-fc-sfp-port-index-list <integer>,…]- Bridge FC Port Index List-
Displays information only about the storage bridges that have the FC ports with the indexes you specify.
[-fc-port-sfp-vendor-list <text>,…]- Bridge FC Port SFP Vendor List-
Displays information only about the storage bridges that have the FC ports with the SFP vendors you specify.
[-fc-port-sfp-serial-number-list <text>,…]- Bridge FC Port SFP Serial Number List-
Displays information only about the storage bridges that have the FC ports with the SFP serial numbers you specify.
[-fc-port-sfp-part-number-list <text>,…]- Bridge FC Port SFP Part Number List-
Displays information only about the storage bridges that have the FC ports with the SFP part numbers you specify.
[-fc-port-sfp-data-rate-capability-list {2Gb|4Gb|8Gb|16Gb}]- Bridge FC Port SFP Data Rate Capability List-
Displays information only about the storage bridges that have the FC ports with the SFP data rate capabilities you specify.
[-fc-port-sfp-data-last-successful-refresh-timestamp {MM/DD/YYYY HH:MM:SS [{+|-}hh:mm]}]- Bridge FC Port SFP Data Last Successful Refresh Timestamp-
Displays information only about the storage bridges that match the FC ports SFP data last successful refresh timestamp you specify.
[-sas-qsfp-port-index-list <integer>,…]- Bridge SAS Port Index List-
[-sas-port-qsfp-vendor-list <text>,…]- Bridge SAS Port QSFP Vendor List-
Displays information only about the storage bridges that have the SAS ports with the QSFP vendors you specify.
[-sas-port-qsfp-serial-number-list <text>,…]- Bridge SAS Port QSFP Serial Number List-
Displays information only about the storage bridges that have the SAS ports with the QSFP serial numbers you specify.
[-sas-port-qsfp-type-list {unknown|optical|active-copper|passive-copper}]- Bridge SAS Port QSFP Type List-
Displays information only about the storage bridges that have the SAS ports with the QSFP types you specify.
[-sas-port-qsfp-part-number-list <text>,…]- Bridge SAS Port QSFP Part Number List-
Displays information only about the storage bridges that have the SAS ports with the QSFP part numbers you specify.
[-sas-port-qsfp-data-last-successful-refresh-timestamp {MM/DD/YYYY HH:MM:SS [{+|-}hh:mm]}]- Bridge SAS Port QSFP Data Last Successful Refresh Timestamp-
Displays information only about the storage bridges that match the SAS ports QSFP data last successful refresh timestamp you specify.
[-mini-sas-hd-index-list <integer>,…]- Bridge Mini-SAS HD Index List-
Displays information only about the storage bridges that have SAS ports with the Mini-SAS HD indexes that you specify.
[-mini-sas-hd-vendor-list <text>,…]- Bridge Mini-SAS HD Vendor List-
Displays information only about the storage bridges that have SAS ports with the Mini-SAS HD vendors that you specify.
[-mini-sas-hd-serial-number-list <text>,…]- Bridge Mini-SAS HD Serial Number List-
Displays information only about the storage bridges that have SAS ports with the Mini-SAS HD serial numbers that you specify.
[-mini-sas-hd-type-list <text>,…]- Bridge Mini-SAS HD Type List-
Displays information only about the storage bridges that have SAS ports with the Mini-SAS HD types that you specify.
[-mini-sas-hd-part-number-list <text>,…]- Bridge Mini-SAS HD Part Number List-
Displays information only about the storage bridges that have SAS ports with the Mini-SAS HD part numbers that you specify.
[-mini-sas-hd-data-last-successful-refresh-timestamp {MM/DD/YYYY HH:MM:SS [{+|-}hh:mm]}]- Bridge Mini-SAS HD Data Last Successful Refresh Timestamp-
Displays information only about the storage bridges that match the SAS ports Mini-SAS HD data with the last successful refresh timestamp that you specify.
[-power-supply-index-list <integer>,…]- Bridge Power Supply Index List-
Displays information only about the storage bridges that have power supplies with the indexes that you specify.
[-power-supply-name-list <text>,…]- Bridge Power Supply Name List-
Displays information only about the storage bridges that have power supplies with the name that you specify.
[-power-supply-status-list {unknown|down|up}]- Bridge Power Supply Status List-
Displays information only about the storage bridges that have power supplies with the status that you specify.
[-power-supply-data-last-successful-refresh-timestamp {MM/DD/YYYY HH:MM:SS [{+|-}hh:mm]}]- Bridge Power Supply Data Last Successful Refresh Timestamp-
Displays information only about the storage bridges that match the power supply last data with the last successful refresh timestamp that you specify.
[-node-list {<nodename>|local}]- Node Name List-
Displays information only about the storage bridges that are connected to the nodes you specify.
[-initiator-list <text>,…]- Initiator List-
Displays information only about the storage bridges that are connected to the nodes hosting the initiators you specify.
[-initiator-side-switch-port-name-list <text>,…]- Initiator Side Switch Port Name List-
Displays information only about the storage bridges that are connected to the initiator side switch ports you specify.
[-target-side-switch-port-name-list <text>,…]- Target Side Switch Port Name List-
Displays information only about the storage bridges that are connected to the target side switch ports you specify.
[-target-port-wwn-list <text>,…]- Target Port WWN List-
Displays information only about the storage bridges that match the target ports with world wide names you specify.
[-target-port-index-list <integer>,…]- Target Port Index List-
Displays information only about the storage bridges that match the target ports with indexes you specify.
The following example displays information about all storage bridges:
cluster1::> storage bridge show
Is Monitor
Bridge Symbolic Name Vendor Model Bridge WWN Monitored Status
ATTO_10.226.197.16
Bridge Number 16 retyped
Atto FibreBridge 6500N
2000001086603824 true ok
ATTO_10.226.197.17
Not Set Atto FibreBridge 6500N
20000010866037e8 true ok
ATTO_10.226.197.18
2000001086609e0e true ok
ATTO_10.226.197.19
2000001086609c06 true ok
4 entries were displayed.
cluster1::>
The following example displays connectivity (node to bridge) information about all storage bridges:
cluster1::> storage bridge show -connectivity
Bridge Name: ATTO_10.226.197.16
Bridge WWN: 2000001086603824
Vendor: Atto
Model: FibreBridge 6500N
Serial Number: FB6500N101405
Firmware Version: 1.60 A68E 51.01
Management IP: 10.226.197.16
Errors: -
Initiator Side Target Side Port
Node Initiator Switch Port Switch Port Target Port WWN No
dpg-mcc-3240-15-b1 0c mcc-cisco-8Gb-fab-3:1-29
mcc-cisco-8Gb-fab-1:1-25
2100001086603824 1
dpg-mcc-3240-15-b2 0c mcc-cisco-8Gb-fab-3:1-30
2100001086603824 1
The following command displays cooling (temperature sensors) information about all storage bridges:
cluster1::> storage bridge show -cooling
Vendor: Atto
Errors: -
Chassis Temperature Sensor:
Min Safe Max Safe
Sensor Name Reading Oper Temp Oper Temp Status
Chassis 42 0 70 normal
Temperature
Sensor
The following command displays the error information about all storage bridges:
cluster1::> storage bridge show -error
ATTO_10.226.197.16(2000001086603824):Bridge is Unreachable over Management Network.
Bridge Name: ATTO_10.226.197.17
Bridge WWN: 20000010866037e8
ATTO_10.226.197.17(20000010866037e8):Bridge is Unreachable over Management Network.
Bridge Name: ATTO_10.226.197.18
Bridge WWN: 2000001086609e0e
ATTO_10.226.197.18(2000001086609e0e):Bridge is Unreachable over Management Network.
Bridge Name: ATTO_10.226.197.19
Bridge WWN: 2000001086609c06
ATTO_10.226.197.19(2000001086609c06):Bridge is Unreachable over Management Network.
The following command displays the detailed information about all the storage bridges:
cluster1::> storage bridge show -instance
Vendor: Atto
Errors: -
The following command displays power supply information about all storage bridges:
cluster1::> storage bridge show -power
Bridge Name: ATTO_10.226.197.47
Bridge WWN: 2000001086601506
Vendor: Atto
Serial Number: FB6500N100526
Firmware Version: 1.60 069G 51.01
Management IP: 10.226.197.47
Errors: -
Last Update Time: -
Bridge Power Supplies:
Power Supply Name Status
Bridge Name: ATTO_10.226.197.48
Bridge WWN: 20000010867002d0
Vendor: Atto
Model: FibreBridge 7500N
Serial Number: FB7500N100018
Firmware Version: 2.00 006U 105.01
Management IP: 10.226.197.48
Errors: -
Last Update Time: 10/22/2015 13:37:37 -04:00
A up
B down
The following command displays port information about all storage bridges:
cluster1::> storage bridge show -ports
Vendor: Atto
Errors: -
FC Ports:
Admin Oper Neg
Ports Status Status Port Mode Speed WWPN
1 enabled online n-port 8gb 2100001086603824
2 enabled offline unknown unknown 2200001086603824
Last Update Time: 8/12/2014 12:34:36 -04:00
SAS Ports:
Neg Data
Data Rate PHY1 PHY2 PHY3 PHY4 Admin Oper
Ports Rate Cap Status Status Status Status Status Status WWPN
1
3Gbps
6Gbps online online online online enabled online 5001086000603824
2
6Gbps
6Gbps offline offline offline offline disabled offline 0000000000000000
The following command displays port SFP information about all storage bridges:
cluster1::> storage bridge show -sfp
Vendor: Atto
Errors: -
Last Update Time: 10/22/2015 13:27:37 -04:00
FC SFP:
Speed
Ports Vendor Serial Number Part Number Capability
1 AVAGO AD1020A01FC AFBR-57D7APZ 8Gbps
2 AVAGO AD1020A01F7 AFBR-57D7APZ 8Gbps
Last Update Timestamp: 10/22/2015 13:27:37 -04:00
SAS QSFP:
Ports Vendor Serial Number SFP Type Part Number
1 Molex Inc. 005820292 passive-copper 112-00176
2 - - unknown -
Last Update Timestamp: -
Mini-SAS HD:
Vendor: Atto
Errors: -
FC SFP:
Speed
1 AVAGO AC1442J00L5 AFBR-57F5MZ 16Gbps
2 AVAGO AC1442J00L0 AFBR-57F5MZ 16Gbps
SAS QSFP:
Mini-SAS HD:
1 Amphenol APF14510026548 Passive Copper 1m ID:00
112-00429
2 - - - -
3 - - - -
4 - - - -
The following command displays port statistics information about all storage bridges:
cluster1::> storage bridge show -stats
Vendor: Atto
Errors: -
FC Ports:
Oper Neg Link Sync CRC Rx Tx
Ports Status Port Mode Speed Failure Losses Error Words Words
1 online n-port 8gb 0 0 0 2721271731 3049186605
2 offline unknown unknown 1 1 0 0 0
Last Update Time: 8/12/2014 12:34:37 -04:00
SAS Ports:
Invalid Disparity Sync PHY Link CRC
SAS PHY Neg Speed Dword Error Loss Reset Changed Error
Port Port Speed Capability Count Count Count Count Count Count
1 0 3Gbps 6Gbps 28262 26665 2 0 1 0
1 1 3Gbps 6Gbps 2110 1794 20 0 1 0
1 2 3Gbps 6Gbps 20435 18857 13 0 1 0
1 3 3Gbps 6Gbps 4573 3353 16 0 1 0
2 0 6Gbps 6Gbps 66 53 0 0 0 0
2 1 6Gbps 6Gbps 27478 25137 2 0 0 0
2 2 6Gbps 6Gbps 20537 17322 9 0 0 0
2 3 6Gbps 6Gbps 23629 21767 10 0 0 0
