network port show-address-filter-info
Print the port’s address filter information
The network port show-address-filter-info
command displays information about the port’s address filter.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. -node <nodename>
- Node-
Use this parameter to specify the node.
-port {<netport>|<ifgrp>}
- Port-
Use this parameter to specify the port. For example, e0c.
[-num-total <integer>]
- Total Number Of Entries-
Use this parameter to specify the total number of entries.
[-num-used <integer>]
- Number Of Used Entries-
Use this parameter to specify the number of used entries.
[-used-entries <text>,…]
- The Used Entries-
Use this parameter to list the used entries.
The following example displays information of the given port’s address filter on the specified node of the cluster.
cluster1::*> network port show-address-filter-info -node local -port e0c Node: node1 Total Number Number of Port of Address Used Address Used Address Name Filter Entries Filter Entries Filter Entries ---- -------------- -------------- ------------------ e0c 1328 3 U 0 a0 98 40 e 6 M 1 80 c2 0 0 e M 1 0 5e 0 0 fb
