network port show-address-filter-info
Print the port's address filter information
The network port show-address-filter-info command displays information about the port's address filter.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. -node <nodename>- Node-
Use this parameter to specify the node.
-port {<netport>|<ifgrp>}- Port-
Use this parameter to specify the port. For example, e0c.
[-num-total <integer>]- Total Number Of Entries-
Use this parameter to specify the total number of entries.
[-num-used <integer>]- Number Of Used Entries-
Use this parameter to specify the number of used entries.
[-used-entries <text>,…]- The Used Entries-
Use this parameter to list the used entries.
The following example displays information of the given port's address filter on the specified node of the cluster.
cluster1::*> network port show-address-filter-info -node local -port e0c
Node: node1
Total Number Number of
Port of Address Used Address Used Address
Name Filter Entries Filter Entries Filter Entries
e0c 1328 3 U 0 a0 98 40 e 6
M 1 80 c2 0 0 e
M 1 0 5e 0 0 fb
