      vserver security trace trace-result delete
Delete security trace results
Delete the specified security tracing event record.
- -node {<nodename>|local}- Node
This parameter specifies the cluster node on which the permission tracing event that you want to delete occurred.
- -vserver <vserver name>- Vserver
This parameter specifies the Vserver on which the permission tracing event that you want to delete occurred.
- -seqnum <integer>- Sequence Number
This parameter specifies the sequence number of the log entry to be deleted.
The following example deletes the security trace result record for the Vserver ``_vserver_1_`` on node ``_Node_1_`` whose sequence number is ``_999_`` .
cluster1::> vserver security trace trace-result delete -vserver vserver_1 -node Node_1 -seqnum 999
 PDFs
PDFs
