network tcpdump trace show
Show list of tcpdump trace files
The network tcpdump trace show command shows the list of tcpdump trace files located in /mroot/etc/log/packet_traces/ directory.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node Name-
Use this parameter to show the list of traces files of a matching node.
[-trace-file <text>]- Trace File-
Use this parameter optionally to show the list of trace files with a matching trace-file name.
The following example shows the list of trace files on nodes "node1" and "node2":
cluster1::> network tcpdump trace show
Node Trace File
node1
e0a_20170314_115624.trc0
node2
e0c_20170314_115624.trc0
