vserver services name-service unix-group load-from-uri
PDF of this doc site
Creating your file...
Load one or more local UNIX groups from a URI
The vserver services name-service unix-group load-from-uri
command loads UNIX groups from a universal resource identifier (URI). The URI must contain group information in the UNIX /etc/group format:
group_name
:password
:group_ID
:comma_separated_list_of_users
The command discards the value of the password
field.
-vserver <vserver>
- Vserver-
Use this parameter to specify the Vserver on which to locate the local UNIX groups.
-uri {(ftp|http)://(hostname|IPv4 Address|'['IPv6 Address']')…}
- URI to Load From-
Use this parameter to specify the URI from which the command loads group information. The URI scheme must be either ftp(s) or http(s)
[-overwrite {true|false}]
- Overwrite Entries-
Use this parameter with the value
true
to specify that group information loaded from the URI should overwrite existing group information. The default value isfalse
, specifying that group information loaded from the URI should not overwrite existing group information. [-skip-name-validation {true|false}]
- Skip Name Validation-
By default, Data ONTAP validates the name to ensure it complies with the following rules:
The name contains only valid characters: 0 through 9, A through Z, a through z, "_", ".", and "-"
The name does not start with "-"
The name does not contain "$" except as the last character
If the parameter is set to
true
, the name validation is skipped. -
[-foreground {true|false}]
- Load Unix Groups file in the Foreground-
If this parameter is set to
false
, the operation runs as a job in the background. Otherwise, the command does not return until the operation is complete. The default value istrue
The following example loads group information from the URI ftp://ftp.example.com/groups onto a Vserver named vs0:
cluster1::> vserver services name-service unix-group load-from-uri -vserver vs0 -uri ftp://ftp.example.com/groups
