network bgp config show
Display BGP configuration
The network bgp config show command displays the border gateway protocol (BGP) configuration for each node.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
This parameter selects the BGP configurations that match the specified node.
 [-asn <integer>]- Autonomous System Number-
This parameter selects the BGP configurations that match the specified autonomous system number.
 [-hold-time <integer>]- Hold Time-
This parameter selects BGP configurations that match the specified hold time.
 [-router-id <IP Address>]- Router ID-
This parameter selects the BGP configurations that match the specfied router ID.
cluster1::> network bgp config show
        Autonomous
        System    Hold Time
    Node    Number    (seconds)  Router ID
    node1    10    180    10.0.1.112
