Command reference
network port show-address-filter-info
Print the port's address filter information
The network port show-address-filter-info command displays information about the port's address filter.
{ [-fields <fieldname>,…​]
| [-instance ] }
-node <nodename> - Node
Use this parameter to specify the node.
-port {<netport>|<ifgrp>} - Port
Use this parameter to specify the port. For example, e0c.
[-num-total <integer>] - Total Number Of Entries
Use this parameter to specify the total number of entries.
[-num-used <integer>] - Number Of Used Entries
Use this parameter to specify the number of used entries.
[-used-entries <text>,…​] - The Used Entries
Use this parameter to list the used entries.
The following example displays information of the given port's address filter on the specified node of the cluster.
cluster1::*> network port show-address-filter-info -node local -port e0c
Node: node1
        Total Number       Number of
Port      of Address    Used Address     Used Address
Name  Filter Entries  Filter Entries       Filter Entries
e0c             1328               3     U 0 a0 98 40 e 6
                                          M 1 80 c2 0 0 e
                                          M 1 0 5e 0 0 fb
