lun import verify stop
Stop the verify for the specified LUN
This command stops the block by block verification of the foreign disk and LUN data.
This command is not supported for a Vserver with Infinite Volume. |
-vserver <Vserver Name>- Vserver Name (privilege: advanced)-
Specifies the Vserver that contains the LUN you want to stop block by block comparison with the foreign disk.
-path <path>- LUN Path (privilege: advanced)-
Specifies the path of the LUN that you want to stop the block by block comparison. Examples of correct LUN paths are
/vol/vol1/lun1and/vol/vol1/qtree1/lun1.
cluster1::> lun import verify stop -vserver vs1 -path /vol/vol2/lun2
Stops the import verify on lun at path /vol/vol2/lun2.
