vserver nfs on
Enable the NFS service of a Vserver
The vserver nfs on command enables NFS access on a Vserver. The Vserver must already exist.
-vserver <vserver name> - Vserver
This parameter specifies the Vserver on which you want to enable NFS access.
The following example enables NFS access on a Vserver named vs0.
cluster1::> vserver nfs on -vserver vs0
