storage aggregate object-store show-freeing-status
Show status of background object freeing work after aggregate delete
The storage aggregate object-store show-freeing-status command displays status information about the background work that frees an aggregate's objects from an object store after a storage aggregate delete .
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-bin-uuid <UUID>]- UUID of the Bin (privilege: advanced)-
If this parameter is specified, the command displays information only about the aggregate attached to the specified bin UUID.
 [-object-store-name <text>]- Object Store Configuration Name (privilege: advanced)-
If this parameter is specified, the command displays information only about object stores whose configuration name matches the specified names.
 [-aggregate-name <aggregate name>]- Aggregate (privilege: advanced)-
If this parameter is specified, the command displays information only about the specified aggregates that were deleted.
 [-request-state {queued|running|cleaning-up}]- Request State (privilege: advanced)-
If this parameter is specified, the command displays information only about the object stores that have the specified object freeing request state.
 [-num-objects-freed <integer>]- Num Objects Freed (privilege: advanced)-
If this parameter is specified, the command displays information only about the object stores that have the specified number of objects that have been freed.
 [-last-error <text>]- The Last Error Encountered (privilege: advanced)-
If this parameter is specified, the command displays information only about the object stores that have the specified last error encountered.
