vserver cifs users-and-groups privilege show
PDF of this doc site
Creating your file...
Your file is ready
Display privileges
The vserver cifs users-and-groups privilege show
command displays privilege overrides assigned to local or Active Directory users or groups.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
