network routing-groups show
(DEPRECATED)-Display routing groups
This command has been deprecated and may be removed from a future version of Data ONTAP. Use the "network route" command set to configure routes instead. |
The network routing-groups show command displays a group of static routes. You can view routes originating from specified servers, and routes with specified names, roles, and number of hops.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver>]- Vserver Name-
Use this parameter to display the routing groups within the specified vserver.
[-routing-group <text>]- Routing Group-
Use this parameter to display the specified routing group.
[-subnet <IP Address/Mask>]- Address/Mask-
Use this parameter to display the routing groups within the specified subnet. The format for this value is: address, slash ("/"), mask. The example below has
192.0.2.165/24as a valid value for the -subnet parameter. [-role {cluster|data|node-mgmt|intercluster|cluster-mgmt}]- Role-
Use this parameter to display the routing groups with the specified role.
[-metric <integer>]- Metric-
Use this parameter to display the routing groups with the specified metric.
[-address-family {ipv4|ipv6|ipv6z}]- Address Family-
Use this parameter to display the routing groups using the specified IP address family. Only IPv4 and IPv6 non-zoned addresses can be used as value for this parameter. IPv6z addresses should not be used.
The following example displays a routing group for data from the virtual server node1.
cluster1::> network routing-groups show -role data
Routing
Server Group Subnet Role Metric
node1 d192.0.2.165/24
192.0.2.165/24 data 20
node2 d192.0.2.166/24
192.0.2.166/24 data 20
2 entries were displayed.
