vserver cifs domain discovered-servers show
Display discovered server information
The vserver cifs domain discovered-servers show command displays information about the discovered servers for the CIFS domains of one or more Vservers. Server displays are grouped by node and Vserver, and each group is preceded by the node and Vserver identification. Within each grouping, the server display is limited to those associated with the domain specified by the domain parameter, if it is present.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
If you use this parameter, the command only displays servers for the specified node.
[-vserver <vserver name>]- Vserver-
If you use this parameter, the command only displays servers for the specified Vserver.
[-domain <TextNoCase>]- Fully Qualified Domain Name-
If you use this parameter, the command only displays servers in the specified domain.
[-type {Unknown|KERBEROS|MS-LDAP|MS-DC|LDAP|NIS}]- Server Type-
If you use this parameter, the command only displays servers of the specified type.
[-name <text>]- Server Name-
If you use this parameter, the command only displays servers the with the specified name. This can result in multiple lines because the same server may provide multiple services.
[-address <InetAddress>]- Server Address-
If you use this parameter, the command only displays servers with the specified IP address. This can result in multiple lines because the same server may provide multiple services.
[-preference {unknown|preferred|favored|adequate}]- Preference-
If you use this parameter, the command only displays servers of the specified preference level.
[-status {OK|unavailable|slow|expired|undetermined|unreachable}]- Status-
If you use this parameter, the command only displays servers of the specified status.
[-dc-functional-level {win2000|unknown|win2003|win2008|win2008r2|win2012|win2012r2|win2016|winthreshold}]- DC Functional Level-
If you use this parameter, the command only displays servers with the specified functional level.
[-is-dc-read-only {true|false}]- Is DC Read Only-
If this parameter is set to true, the command only displays servers with read only domain controller. If set to false, the command only displays servers with writable domain controller.
The following example display shows the information provided by this command.
cluster1::> vserver cifs domain discovered-servers show Node: node1 Vserver: vs1 Domain Name Type Preference DC-Name DC-Address Status --------------- -------- ---------- --------------- --------------- --------- "" NIS preferred 192.168.10.222 192.168.10.222 OK example.com MS-LDAP adequate DC-1 192.168.192.24 OK example.com MS-LDAP adequate DC-2 192.168.192.25 OK example.com MS-DC adequate DC-1 192.168.192.24 OK example.com MS-DC adequate DC-2 192.168.192.25 OK 5 entries were displayed.
