storage pool show-aggregate
Display aggregates provisioned from storage pools
The storage pool show-aggregate
command displays allocation information for SSD storage pools in the cluster. The command output depends upon the parameter or parameters specified with the command. If no parameters are specified, the command displays information about allocations of all storage pools in the cluster.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-storage-pool <storage pool name>]
- Name of Storage Pool-
Selects the storage pools that match this parameter value.
[-aggregate <aggregate name>]
- Aggregate-
[-capacity {<integer>[KB|MB|GB|TB|PB]}]
- Capacity-
Capacity includes space provided by data and parity portions of each allocation unit. Only the data portions of each allocation unit contribute to the cache or usable capacity of Flash Pool or All-Flash aggregates respectively .
[-allocated-unit-count <integer>]
- Number of AU’s Assigned to This Aggregate-
[-original-owner <text>]
- Original Owner Name-
[-node {<nodename>|local}]
- Node-
Display information about the aggregate or aggregates using a storage pool called SP2
cluster1::> storage pool show-aggregate -storage-pool SP2 -instance Name of Storage Pool: SP2 Aggregate: node2_flashpool_1 Capacity: 744.9GB Number of AU's Assigned to This Aggregate: 1 Original Owner Name: node2 Node: node2
