vserver vscan connection-status show-not-connected
Display connection status of Vscan servers which are allowed to connect but not yet connected
The vserver vscan connection-status show-not-connected command displays connection status information of the external virus-scanning servers, or "Vscan servers" that are ready to accept connection but are not yet connected. This command could be useful for troubleshooting. If you do not specify any parameters, the command displays the following information for all Vscan servers:
Vserver name
Node name
Vscan server
Connection status
Disconnect reason
You can specify the -fields parameter to specify which fields of information to display. In addition to the fields above, you can display the following fields:
Server type
Vscan server disconnected since
This command is not supported for a Vserver with Infinite Volume. |
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
If you specify this parameter, the command displays information only about the Vscan servers attached to the specified node.
[-vserver <vserver name>]- Vserver-
If you specify this parameter, the command displays information only about the Vscan servers for the specified Vserver.
[-server <IP Address>]- Server-
If you specify this parameter, the command displays information only about the Vscan server that you specify.
[-server-status <Status>]- Server Status-
If you specify this parameter, the command displays information only about the Vscan servers that have the specified status.
[-disconnect-reason <reason>]- Server Disconnect Reason-
If you specify this parameter, the command displays information only about the Vscan servers that are disconnected because of the specified reason.
[-disconnected-since <MM/DD/YYYY HH:MM:SS>]- Time When Vscan Server Was Disconnected-
If you specify this parameter, the command displays information only about the Vscan servers that have been disconnected since the specified time.
[-server-type <Server type>]- Server Type-
If you specify this parameter, the command displays information only about the Vscan servers that have the specified server type.
The following example displays connection-status information about all Vscan servers which are ready to accept connection but not yet connected.
cluster1::> vserver vscan connection-status show-not-connected
Connection Disconnect
Vserver Node Server Status Reason
vs2 Cluster-01 3.3.3.3 disconnected invalid-
session-id
vs2 Cluster-01 4.4.4.4 disconnected remote-closed
2 entries were displayed.
The following example displays detailed connection-status information about Vscan servers which are disconnected because the connection is remotely closed.
cluster1::> vserver vscan connection-status show-not-connected -instance
-disconnect-reason remote-closed
Node: Cluster-01
Vserver: vs2
Server: 4.4.4.4
Server Status: disconnected
Server Disconnect Reason: remote-closed
Time When Vscanner Was Disconnected: 6/4/2013 06:51:32
Server Type: primary
