template upload
Upload an existing template to an external server
Use this command to upload an existing template on to an external server.
-name <template name>- Name of the template (privilege: advanced)-
This parameter specifies the name of the template.
-uri {(ftp|http)://(hostname|IPv4 Address|'['IPv6 Address']')…}- URI to upload the template (privilege: advanced)-
This parameter specifies the URI to which the template will be uploaded.
The following example uploads a template template1 on to an external server specified in the uri input parameter:
cluster1::*> template upload -name template1 -uri http://www.example.com/mytemplates/
