vserver cifs security show
Display CIFS security settings
The vserver cifs security show command displays information about CIFS server security settings.
[-fields <fieldname>,…] -
If you specify the -fields parameter, the command only displays the fields that you specify.
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver-
This parameter specifies the name of the Vserver whose CIFS security settings you want to display.
[-kerberos-clock-skew <integer>]- Maximum Allowed Kerberos Clock Skew-
If this parameter is specified, the command displays information only about the security settings that match the specified Kerberos ticket clock skew.
[-kerberos-ticket-age <integer>]- Kerberos Ticket Lifetime-
If this parameter is specified, the command displays information only about the security settings that match the specified Kerberos ticket age.
[-kerberos-renew-age <integer>]- Maximum Kerberos Ticket Renewal Days-
If this parameter is specified, the command displays information only about the security settings that match the specified Kerberos renewal age.
[-kerberos-kdc-timeout <integer>]- Timeout for Kerberos KDC Connections (Secs)-
If this parameter is specified, the command displays information only about the security settings that match the specified Kerberos KDC timeout.
[-realm <text>]- Kerberos Realm-
If this parameter is specified, the command displays information only about the security settings that match the specified Kerberos realm.
[-kdc-ip <text>,…]- KDC IP Address-
If this parameter is specified, the command displays information only about the security settings that match the specified KDC IP address.
[-kdc-name <text>,…]- KDC Name-
If this parameter is specified, the command displays information only about the security settings that match the specified KDC name.
[-site <text>,…]- KDC Site-
If this parameter is specified, the command displays information only about the security settings that match the specified Windows site.
[-is-signing-required {true|false}]- Require Signing for Incoming CIFS Traffic-
This parameter specifies whether signing is required for incoming CIFS traffic. If this parameter is specified, the command displays information only about the security settings that match the specified value for is-signing-required.
[-is-password-complexity-required {true|false}]- Require Password Complexity for Local User Accounts-
If this parameter is set to
true, the command displays CIFS security configuration information only for CIFS servers where password complexity for local user accounts is required. If set tofalse, the command displays security configuration information for CIFS servers where password complexity for local user accounts is not required. [-use-start-tls-for-ad-ldap {true|false}]- Use start_tls for AD LDAP Connections-
true, the command displays CIFS security configuration information only for CIFS servers where Start TLS is used for communication with the AD LDAP Server. If set tofalse, the command displays CIFS security configuration information only for CIFS servers where Start TLS is not used for communication with the AD LDAP Server. [-is-aes-encryption-enabled {true|false}]- Is AES-128 and AES-256 Encryption for Kerberos Enabled-
true, the command displays CIFS security configuration information only for CIFS servers where AES-128 and AES-256 encryption types for Kerberos are enabled. If set tofalse, the command displays security configuration information for CIFS servers where AES-128 and AES-256 encryption types for Kerberos are disabled. [-lm-compatibility-level {lm-ntlm-ntlmv2-krb|ntlm-ntlmv2-krb|ntlmv2-krb|krb}]- LM Compatibility Level-
If this parameter is specified, the command displays information only about the security settings that match the specified LM compatibility level.
[-is-smb-encryption-required {true|false}]- Require SMB Encryption for Incoming CIFS Traffic-
true, the command displays CIFS security configuration information only for CIFS servers where SMB encryption is required. If set tofalse, the command displays security configuration information for CIFS servers where SMB encryption is not required. [-session-security-for-ad-ldap {none|sign|seal}]- Client Session Security-
seal, the command displays CIFS security configuration information only for CIFS servers where both signing and sealing are required for LDAP communications. If set tosign, the command displays security configuration information for CIFS servers where only signing is required for LDAP communications. If set tonone, the command displays security configuration information for CIFS servers where no security is required for LDAP communications. [-smb1-enabled-for-dc-connections {false|true|system-default}]- SMB1 Enabled for DC Connections-
true, the command displays CIFS security configuration information only for CIFS servers where SMB1 is enabled for use with connections to domain controllers. If set tofalse, the command displays security configuration information for CIFS servers where SMB1 is not enabled for use with connections to domain controllers. If set tosystem-default, the command displays security configuration information for CIFS servers where the system-default setting (SMB1 enabled) is used for connections to domain controllers. [-smb2-enabled-for-dc-connections {false|true|system-default}]- SMB2 Enabled for DC Connections-
true, the command displays CIFS security configuration information only for CIFS servers where SMB2 is enabled for use with connections to domain controllers. If set tofalse, the command displays security configuration information for CIFS servers where SMB2 is not enabled for use with connections to domain controllers. If set tosystem-default, the command displays security configuration information for CIFS servers where the system-default setting (SMB2 enabled) is used for connections to domain controllers.
The following example displays CIFS server security settings.
cluster1::> vserver cifs security show
Vserver: vs1
Kerberos Clock Skew: 3 minutes
Kerberos Ticket Age: 8 hours
Kerberos Renewal Age: 7 days
Kerberos KDC Timeout: 3 seconds
Is Signing Required: true
Is Password Complexity Required: true
Use start_tls For AD LDAP connection: false
Is AES Encryption Enabled: false
LM Compatibility Level: krb
Is SMB Encryption Required: false
Client Session Security: none
SMB1 Enabled For DC Connections: system-default
SMB2 Enabled For DC Connections: system-default
The following example displays the Kerberos clock skew for all Vservers.
cluster1::> vserver cifs security show -fields kerberos-clock-skew
vserver kerberos-clock-skew
vs1 5
