vserver cifs share access-control show
Display access control lists on CIFS shares
The vserver cifs share access-control show command displays the ACLs of CIFS shares.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver
This optional parameter specifies the name of the Vserver containing the share for which you want to display the access control list.
[-share <Share>] - Share Name
This optional parameter specifies the name of the CIFS share for which you want to display the access control list.
[-user-or-group <TextNoCase>] - User/Group Name
If you specify this optional parameter, the command displays only access control lists for the CIFS shares that have ACLs matching the specified user or group.
[-user-group-type {windows|unix-user|unix-group}] - User or Group Type
If you specify this optional parameter, the command displays only access control lists for the CIFS shares that have ACLs matching the specified user-group-type. The user-group-type can be one of the following:
  • windows
  • unix-user
  • unix-group
[-permission <access rights>] - Access Type
If you specify this optional parameter, the command displays only access control lists for the CIFS shares that have ACLs matching the specified permission. The permissions can be one of the following:
  • No_access
  • Read
  • Change
  • Full_Control
[-winsid <windows sid>] - Windows SID
If you specify this optional parameter, the command displays only access control lists for the CIFS shares that have ACLs matching the specified Windows SID.
[-access-mask <Hex Integer>] - Access mask
If you specify this optional parameter, the command displays only access control lists for the CIFS shares that have ACLs matching the specified access rights.
The following example displays all the ACLs for shares in Vserver vs1.
vs1::> vserver cifs share access-control show
               Share       User/Group                  User/Group  Access
Vserver        Name        Name                        Type        Permission
vs1            vol3        CIFSQA\administrator        windows     Read
vs1            vol3        Everyone                    windows     Full_Control
vs1            vol3        pcuser                      unix-user   Read
vs1            vol3        daemon                      unix-group  Read
