event filter rule delete
Delete a rule for an event filter
The event filter rule delete command deletes a rule from an event filter. The position of all the rules following the deleted rule is updated to maintain a contiguous sequence. Use event filter show command to view the filters and the rules associated with them.
-filter-name <text>- Filter Name-
Use this mandatory parameter to specify the name of the event filter from which you want to delete the rule. Rules cannot be deleted from system-defined filters.
-position <integer>- Rule Position-
Use this mandatory parameter to specify the position of the rule to delete from the filter. It should be in the range (1..n-1), where 'n' is the position of the last rule, which is an implicit rule.
The following example deletes a rule at position 2 from an existing event filter "emer-and-wafl":
cluster1::> event filter show
Filter Name Rule Rule Message Name SNMP Trap Type Severity
Position Type
default-trap-events
1 include * * EMERGENCY, ALERT
2 include * Standard, Built-in
3 exclude * * *
emer-and-wafl
1 include wafl.scan.* * ALERT
2 include wafl.* * EMERGENCY
3 include * Standard *
4 exclude * * *
important-events
2 include callhome.* * ERROR
3 exclude * * *
no-info-debug-events
1 include * * EMERGENCY, ALERT, ERROR, NOTICE
2 exclude * * *
12 entries were displayed.
cluster1::> event filter rule delete -filter-name emer-and-wafl -position 2
Position Type
default-trap-events
3 exclude * * *
emer-and-wafl
2 include * Standard *
3 exclude * * *
important-events
3 exclude * * *
2 exclude * * *
11 entries were displayed.
