network tcpdump trace delete
PDF of this doc site
Creating your file...
Your file is ready
Delete a tcpdump tracefile
The network tcpdump trace delete
command deletes the tcpdump trace file from a matching node.
-node {<nodename>|local}
- Node Name-
Use this parameter to delete the tcpdump trace file from a matching node.
-trace-file <text>
- Trace File-
Use this parameter to specify the tcpdump trace file to be deleted.
The following example deletes the list of tcpdump trace files from node "node1" using wildcard pattern:
cluster1::> network tcpdump trace delete -node node1 -trace-file *
