cluster peer connection show
Show current peering connections for a cluster
The cluster peer connection show command displays information about the current TCP connections and how they are supporting the set of peering relationships.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-cluster-name <text>]- Remote Cluster-
Selects the connections associated with the named peered cluster.
[-node {<nodename>|local}]- Node-
Selects the connections hosted by the given node.
[-connection-type {mgmt-client|mgmt-server|data}]- Cluster Peering Connection Type-
Selects the connections of the named type. This parameter can have one of three different values:
Mgmt-client - Management-plane client connections, created so that this node may make management-plane requests of other nodes.
Mgmt-server - Management-plane server connections, over which this node services requests made by other nodes' mgmt-client connections.
Data - Connections made between data-planes of different nodes.
[-index <integer>]- Index of Connection-
Selects the connections with the given index value.
[-cluster-uuid <UUID>]- Cluster UUID (privilege: advanced)-
Selects the connections to the cluster with the given cluster UUID.
[-auth-status-admin {no-authentication|revoked|use-authentication}]- Authentication Status Administrative-
Selects connections to the peered clusters whose intended authentication matches this parameter value.
[-auth-status-operational {ok|absent|pending|expired|revoked|declined|refused|ok-and-offer|absent-but-offer|revoked-but-offer|key-mismatch|intent-mismatch|incapable}]- Authentication Status Operational-
Selects connections to the peered clusters whose authentication state matches this parameter value.
[-authenticated {true|false}]- Authenticated-
Selects connections that have been authenticated, or not, according to this parameter value.
[-port <integer>]- Network Port-
Selects the connections that match this parameter value.
[-idle <[<integer>h][<integer>m][<integer>s]>]- Idle Time-
Selects the connections whose idle times match this parameter value.
[-address <IP Address>]- Remote Network Address-
Selects the connections that have this parameter value as the remote network address.
This example shows the output of the cluster peer connection show command.
cluster1::> cluster peer connection show
Cluster Node Connection Type Auth Encrypt Idle Remote Address
cluster2 Authentication: ok
node1
data true true 6s 10.10.10.100
data true true 7s 10.10.10.100
data true true 20s 10.10.10.100
data true true 11s 10.10.10.100
data true true 11s 10.10.10.200
data true true 48s 10.10.10.200
data true true 37s 10.10.10.200
12 entries were displayed.
