vserver vscan on-demand-task show
Display On-Demand tasks
The vserver vscan on-demand-task show command displays information about the On-Demand tasks belonging to the Vserver. If you do not specify any parameters, the command displays the following information about all On-Demand tasks:
Vserver name
Task name
Scan paths
Report directory path
Schedule
You can specify the -fields parameter to specify which fields of information to display about On-Demand tasks. In addition to the fields above, you can display the following fields:
Max file size
File paths to exclude
File extensions to exclude
File extensions to include
Scan files without extension
Scan timeout
Cross junction
Directory recursion
Scan priority
Report log level
This command is not supported for a Vserver with Infinite Volume. |
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver-
If you specify this parameter, the command displays information only about the On-Demand tasks for the specified Vserver.
[-task-name <text>]- Task Name-
If you specify this parameter, the command displays information only about the specified On-Demand task.
[-scan-paths <text>,…]- List of Scan Paths-
If you specify this parameter, the command displays information only about the On-Demand tasks that have the specified path or paths in the scan-paths list.
[-report-directory <text>]- Report Directory Path-
If you specify this parameter, the command displays information only about the On-Demand tasks that have the specified report-directory.
[-schedule <text>]- Job Schedule-
If you specify this parameter, the command displays information only about the On-Demand tasks that have the specified schedule.
[-max-file-size {<integer>[KB|MB|GB|TB|PB]}]- Max File Size Allowed for Scanning-
If you specify this parameter, the command displays information only about the On-Demand tasks that have the specified max-file-size.
[-paths-to-exclude <text>,…]- File Paths Not to Scan-
If you specify this parameter, the command displays information only about the On-Demand tasks that have the specified path or paths in the exclude list.
[-file-ext-to-exclude <File extension>,…]- File Extensions Not to Scan-
If you specify this parameter, the command displays information only about the On-Demand tasks that have the specified file extension or extensions in the exclude list.
[-file-ext-to-include <File extension>,…]- File Extensions to Scan-
If you specify this parameter, the command displays information only about the On-Demand tasks that have the specified file extension or extensions in the include list.
[-scan-files-with-no-ext {true|false}]- Scan Files with No Extension-
If you specify this parameter, the command displays information only about the On-Demand tasks that have the specified value.
[-request-timeout <[<integer>h][<integer>m][<integer>s]>]- Request Service Timeout-
If you specify this parameter, the command displays information only about the On-Demand tasks that have the specified request-timeout.
[-cross-junction {true|false}]- Cross Junction-
[-directory-recursion {true|false}]- Directory Recursion-
[-scan-priority {low|normal}]- Scan Priority-
If you specify this parameter, the command displays information only about the On-Demand tasks that have the specified scan-priority.
[-report-log-level {verbose|info|error}]- Report Log Level-
If you specify this parameter, the command displays information only about the On-Demand tasks that have the specified report-log-level.
The following example displays information about all On-Demand tasks:
cluster1::> vserver vscan on-demand-task show
Report
Vserver Task Name Scan Paths Directory Path Schedule
vs1 t1 /test /report -
vs2 t2 /, /test/ /report daily
2 entries were displayed.
The following example displays detailed information about an On-Demand task:
cluster1::> vserver vscan on-demand-task show -instance -vserver vs1 -task-name t1
Vserver: vs1
Task Name: t1
List of Scan Paths: /test
Report Directory Path: /report
Job Schedule: -
Max File Size Allowed for Scanning: 2GB
File Paths Not to Scan: /vol1/cold-files/
File Extensions Not to Scan: mp3, mp4
File Extensions to Scan: *
Scan Files with No Extension: true
Request Service Timeout: 1m
Cross Junction: true
Directory Recursion: true
Scan Priority: low
Report Log Level: verbose
