storage port rescan
Rescan a storage port
The storage port rescan command rescans a specified storage port.
-node {<nodename>|local}- Node (privilege: advanced)-
Use this parameter to specify the node on which the port resides.
-port <text>- Port (privilege: advanced)-
Use this parameter to specify the port that needs to be rescanned.
The following example rescans port 0a on node node1:
cluster1::> storage port rescan -node node1 -port 0a
