The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
storage port rescan
PDF of this doc site
Creating your file...
Your file is ready
Rescan a storage port
The storage port rescan
command rescans a specified storage port. This command is not supported on Ethernet storage ports (type = ENET).
-node {<nodename>|local}
- Node (privilege: advanced)-
Use this parameter to specify the node on which the port resides.
-port <text>
- Port (privilege: advanced)-
Use this parameter to specify the port that needs to be rescanned.
The following example rescans port 0a on node node1:
cluster1::> storage port rescan -node node1 -port 0a
