ONTAP commands
storage port rescan
Rescan a storage port
The storage port rescan command rescans a specified storage port. This command is not supported on Ethernet storage ports (type = ENET).
-node {<nodename>|local} - Node (privilege: advanced)
Use this parameter to specify the node on which the port resides.
-port <text> - Port (privilege: advanced)
Use this parameter to specify the port that needs to be rescanned.
The following example rescans port 0a on node node1:
cluster1::> storage port rescan -node node1 -port 0a
