The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver audit delete
PDF of this doc site
Creating your file...
Your file is ready
Delete audit configuration
The vserver audit delete
command deletes the audit configuration for a Vserver.
-vserver <vserver name>
- Vserver-
This parameter specifies the name of the Vserver associated with the audit configuration to be deleted.
[-force <true>]
- Force Delete (privilege: advanced)-
This parameter is used to forcibly delete the audit configuration. By default the setting is
false
The following example deletes the audit configuration for Vserver vs1.
cluster1::> vserver audit delete -vserver vs1
