security login motd modify
Modify the message of the day
The security login motd modify
command updates the message of the day (MOTD).
There are two categories of MOTDs: the cluster-level MOTD and the data Vserver-level MOTD. A user logging in to a data Vserver’s clustershell will potentially see two messages: the cluster-level MOTD followed by the Vserver-level MOTD for that Vserver. The cluster administrator can enable or disable the cluster-level MOTD on a per-Vserver basis. If the cluster administrator disables the cluster-level MOTD for a Vserver, a user logging into the Vserver will not see the cluster-level message. Only a cluster administrator can enable or disable the cluster-level message.
-vserver <Vserver Name>
- Vserver Name-
Use this parameter to specify the Vserver whose MOTD will be modified. Use the name of the cluster admin Vserver to modify the cluster-level message.
[-message <text>]
- Message of the Day (MOTD) -
This optional parameter can be used to specify a message. If you use this parameter, the MOTD cannot contain newlines (also known as end of lines (EOLs) or line breaks). If you do not specify any parameter other than the
-vserver
parameter, you will be prompted to enter the message interactively. Messages entered interactively can contain newlines. Non-ASCII characters must be provided as Unicode UTF-8.The message may contain dynamically generated content using the following escape sequences:
- A single backlash character. -
\b
- No output: supported for compatibility with Linux only. -
\C
- Cluster name. -
\d
- Current date as set on the login node. -
\t
- Current time as set on the login node. -
\I
- Incoming LIF IP address (prints 'console' for a console login). -
\l
- Login device name (prints 'console' for a console login). -
\L
- Last login for the user on any node in the cluster. -
\m
- Machine architecture. -
\n
- Node or data Vserver name. -
\N
- Name of user logging in. -
\o
- Same as \O. Provided for Linux compatibility. -
\O
- DNS domain name of the node. Note that the output is dependent on the network configuration and may be empty. -
\r
- Software release number. -
\s
- Operating system name. -
\u
- Number of active clustershell sessions on the local node. For the cluster admin: all clustershell users. For the data Vserver admin: only active sessions for that data Vserver. -
\U
- Same as \u, but has 'user' or 'users' appended. -
\v
- Effective cluster version string. -
\W
- Active sessions across the cluster for the user logging in ('who').
A backslash followed by any other character is emitted as entered.
[-uri {(ftp|http)://(hostname|IPv4 Address|'['IPv6 Address']')…}]
- Download URI for the MOTD } -
Use this parameter to specify the URI from where the message of the day will be downloaded. Note that the message must not exceed 2048 bytes in length. Non-ASCII characters must be provided as Unicode UTF-8.
[-is-cluster-message-enabled {true|false}]
- Is Cluster-level Message Enabled?-
Use this parameter to enable or disable the display of the cluster-level MOTD for the specified Vserver.
This example shows how to enter a MOTD interactively:
cluster1::> security login motd modify -vserver vs0 Enter the message of the day for Vserver "vs0". Max size: 2048. Enter a blank line to terminate input. Press Ctrl-C to abort. 0 1 2 3 4 5 6 7 8 12345678901234567890123456789012345678901234567890123456789012345678901234567890 Welcome to the Vserver! cluster1::>
