cluster peer show
Display peer cluster information
The cluster peer show command displays information about the peering relationships between the current cluster and other clusters. Cluster peering enables independent clusters to coordinate and exchange data.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-cluster <text>]- Peer Cluster Name-
Selects the peered clusters that match this parameter value.
 [-cluster-uuid <UUID>]- Cluster UUID (privilege: advanced)-
 [-peer-addrs <Remote InetAddress>,…]- Remote Intercluster Addresses-
Selects the peered clusters that match this parameter value (remote-host name or IP address).
 [-availability <availability>]- Availability of the Remote Cluster-
Selects the peered clusters that match this parameter value. This parameter can have four different values:
Available - The peer cluster availability status will be
Availableonly if all the nodes in the local cluster are able to contact all the nodes in the remote cluster. -
Partial - The peer cluster availability status will be
Partialonly if some nodes in the local cluster are not able to contact some or all nodes in the peer cluster. -
Unavailable - The peer cluster availability status will be
Unavailableonly if all the nodes in the local cluster are not able to contact any node in the peer cluster. -
Pending - The peer cluster availability status will be
Pendingwhile the system is creating in-memory health data. -
Unidentified - The peer cluster availability status will be Unidentified if the cluster peer offer is created for an anonymous cluster and is unused. When the offer is used, then the availability will get changed to any of the above mentioned status.
Note: If one or more nodes in the local cluster are offline or unreachable, then those nodes are not used to determine the availability status for the remote nodes.
 [-rcluster <text>]- Remote Cluster Name-
 [-ip-addrs <Remote InetAddress>,…]- Active IP Addresses-
 [-serialnumber <Cluster Serial Number>]- Cluster Serial Number-
 [-remote-cluster-nodes <text>,…]- Remote Cluster Nodes-
 [-remote-cluster-health {true|false}]- Remote Cluster Health-
true - This means that there is cluster quorum in the peer cluster.
false - This means that there is no cluster quorum in the peer cluster.
 [-unreachable-local-nodes <text>,…]- Unreachable Local Nodes-
 [-timeout <integer>]- Operation Timeout (seconds) (privilege: advanced)-
 [-address-family {ipv4|ipv6}]- Address Family of Relationship-
Selects the peered clusters that have a relationship established using this protocol.
 [-auth-status-admin {no-authentication|revoked|use-authentication}]- Authentication Status Administrative-
Selects the peered clusters that match this parameter value, which must be chosen from the following values.
no-authentication - The cluster peer relationship uses no authentication.
use-authentication - The cluster peer relationship is authenticated.
revoked - The cluster peer relationship is revoked until agreement can be reached.
 [-auth-status-operational {ok|absent|pending|expired|revoked|declined|refused|ok-and-offer|absent-but-offer|revoked-but-offer|key-mismatch|intent-mismatch|incapable}]- Authentication Status Operational-
Selects the peered clusters that match this parameter value, which must be one of the following values.
ok - The clusters both use authentication and they have agreed on an authentication key.
absent - The clusters agree not to use authentication.
pending - This cluster has made an outstanding offer to authenticate with the other cluster, but agreement has not yet been reached.
expired - This cluster's offer to authenticate with the other cluster expired before agreement was reached.
revoked - This cluster has revoked any prior authentication agreement.
declined - The other cluster has revoked the authentication agreement and is declining to communicate with this cluster.
refused - The other cluster actively refuses the communication attempts, perhaps because its part of the peering relationship has been deleted.
ok-and-offer - The clusters agree on an authentication key and are using it. In addition, this cluster has made an outstanding offer to re-authenticate with the other cluster.
absent-but-offer - The clusters currently agree that neither side requires authentication of the other, but this cluster has made an outstanding offer to authenticate.
revoked-but-offer - This cluster has revoked any authentication agreement, but it has made an outstanding offer to authenticate.
intent-mismatch - The two clusters disagree on whether authentication is required.
key-mismatch - The two clusters both believe that they are authenticated, but one of the shared secrets has become corrupted.
incapable - The other cluster is no longer running a version of Data ONTAP that supports authenticated cluster peering.
 [-rpc-connect-timeout <integer>]- Timeout for RPC Connect (privilege: advanced)-
 [-update-ping-timeout <integer>]- Timeout for Update Pings (privilege: advanced)-
 [-last-updated <MM/DD/YYYY HH:MM:SS>]- Last Update Time-
 [-ipspace <IPspace>]- IPspace for the Relationship-
Selects the peered clusters whose relationships are to cross the named local IPspace. The default value is the IPspace name "Default". In relationships created before ONTAP 8.3.1, the initial value is "-" and is not updated to "Default" until an action is taken on a cluster peer relationship, such as creating, modifying, or deleting a relationship.
This example shows the output of the cluster peer show command when all nodes in the local cluster are able to contact all nodes in the remote peer cluster. Additionally, the peer relationship is authenticated and operating correctly.
cluster1::> cluster peer show Peer Cluster Name Cluster Serial Number Availability Authentication ------------------------- --------------------- -------------- -------------- cluster2 1-80-123456 Available ok
Detailed information for this scenario is shown below.
cluster1::> cluster peer show -instance
Peer Cluster Name: cluster2
       Remote Intercluster Addresses: cluster2-d2, 10.98.234.246
  Availability of the Remote Cluster: Available
                 Remote Cluster Name: cluster2
                 Active IP Addresses: 10.98.234.246, 10.98.234.243
               Cluster Serial Number: 1-80-123456
                Remote Cluster Nodes: cluster2-01, cluster2-02
               Remote Cluster Health: true
             Unreachable Local Nodes: -
      Address Family of Relationship: ipv4
Authentication Status Administrative: use-authentication
   Authentication Status Operational: ok
                    Last Update Time: 02/05 21:05:41
        IPspace for the Relationship: Default
This example shows the output of the cluster peer show command when some nodes in the local cluster are not able to contact some or all of the nodes in the remote peer cluster.
  Availability of the Remote Cluster: Partial
               Remote Cluster Health: false
This example shows the output of the cluster peer show command when some nodes in the local cluster cannot be contacted from the node where the command is executed, but all the other nodes including node on which command is executed are able to contact all nodes in the remote peer cluster.
             Unreachable Local Nodes: cluster1-01
This example shows the output of the cluster peer show command when some nodes in the local cluster cannot be contacted from the node where the command is executed, and the node on which command is executed is also not able to contact the remote peer cluster.
cluster1::> cluster peer show Peer Cluster Name Cluster Serial Number Availability Authentication ------------------------- --------------------- -------------- -------------- cluster2 1-80-123456 Unavailable ok
  Availability of the Remote Cluster: Unavailable
               Remote Cluster Health: -
This example shows the output of the cluster peer show command when all the nodes in the local cluster are not able to contact any nodes in the remote peer cluster.
This example shows the output of the cluster peer show command while the system is creating in-memory health data.
cluster1::> cluster peer show Peer Cluster Name Cluster Serial Number Availability Authentication ------------------------- --------------------- -------------- -------------- cluster2 1-80-123456 Pending ok
  Availability of the Remote Cluster: Pending
                Remote Cluster Nodes: -
This example shows the output of the cluster peer show command for the offer created for an anonymous cluster:
Clus_4gHR                 -                     Unidentified   pending
Peer Cluster Name: Clus_4gHR
            Remote Intercluster Addresses: -
       Availability of the Remote Cluster: Unidentified
                      Remote Cluster Name: Clus_4gHR
                    Cluster Serial Number: -
