vserver cifs character-mapping show
Display character mapping on volumes
The vserver cifs character-mapping show command displays information about character mapping configured for volumes. The command output depends on the parameter or parameters specified with the command. If you do not specify any parameters, the command displays the following information about character mapping configured for volumes:
Vserver name
Volume name
Character mapping
[-fields <fieldname>,…] -
If you specify this parameter, the command displays only the fields that you specify.
[-instance ]} -
If you specify the -instance parameter, the command displays detailed information about all entries.
 [-vserver <vserver name>]- Vserver-
If you specify this parameter, the command displays information about character mapping configured for all the volumes that belong to the specified Vserver.
 [-volume <volume name>]- Volume Name-
If you specify this parameter, the command displays information about the character mapping configured for all the volumes that match the specified volume name.
 [-mapping <text>,…]- Character Mapping-
If you specify this parameter, the command displays information about the character mapping configured for all volumes that match the specified mapping.
The following example displays information about all character mappings configured for volumes
cluster1::> vserver cifs character-mapping show Vserver Volume Name Character Mapping -------------- ----------- ------------------------------------------ vs1 vol1 3c:e17d, 3e:f17e
