vserver cifs share delete
Delete a CIFS share
The vserver cifs share delete
command deletes a CIFS share.
-vserver <vserver name>
- Vserver-
This parameter specifies the Vserver from which you want to delete a CIFS share.
-share-name <Share>
- Share-
This parameter specifies the name of the CIFS share you want to delete.
The following example deletes a CIFS share named share1 from a Vserver named vs1.
cluster1::> vserver cifs share delete -vserver vs1 -share-name share1
