network port ifgrp remove-port
Remove a port from an interface group
The network port ifgrp remove-port command removes a network port from a port interface group.
-node {<nodename>|local}- Node-
The node on which the port interface group is located.
-ifgrp {<netport>|<ifgrp>}- Interface Group Name-
The port interface group from which a port will be removed.
-port <netport>- Specifies the name of port.-
The network port that will be removed from the port interface group.
The following example removes port e0d from port interface group a1a on a node named node1:
cluster1::> network port ifgrp remove-port -node node1 -ifgrp a1a -port e0d
