vserver vscan show
Display Vscan status
The `vserver vscan show ` command displays Vscan status information of the Vservers. If you do not specify any parameters, the command displays the following information about all Vservers:
Vserver name
Vscan status
This command is not supported for a Vserver with Infinite Volume. |
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver-
If you specify this parameter, the command displays information only about the specified Vserver.
[-vscan-status {on|off}]- Vscan Status-
If you specify this parameter, the command displays information only about the Vservers that have the specified status.
The following example displays the Vscan status information.
cluster1::> vserver vscan show Vserver Vscan Status -------------- ------------ vs1 on vs2 off 2 entries were displayed.
