qos workload show
Display a list of workloads
Shows the current status of workloads on a cluster. Use this command to determine the types of workloads that are currently on a cluster. The types of workloads include: system-defined, preset, and user-defined. The system generates system-defined and preset workloads. You cannot create, modify, or delete these workloads. Also, you can only modify or delete a user-defined workload , but cannot create one
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-workload <text>]- Workload Name-
If you use this parameter, the command displays the workloads that contain the specified workload name.
[-uuid <UUID>]- Workload UUID (privilege: advanced)-
If you use this parameter, the command displays the workloads that contain the specified UUID.
[-class {preset|user-defined|system-defined|autovolume}]- Workload Class-
If you use this parameter, the command displays the workloads that contain the specified class. The Class options include system-defined, preset, and user-defined.
[-wid <integer>]- Workload ID-
If you use this parameter, the command displays the workloads that contain the specified internal workload ID.
[-category <text>]- Workload Category-
If you use this parameter, the command displays the workloads that contain the specified category. The category options include Scanner and Efficiency.
[-policy-group <text>]- Policy Group Name-
If you use this parameter, the command displays the workloads that match the specified policy group name.
[-read-ahead <text>]- Read-ahead Tunables-
If you use this parameter, the command displays the workloads that contain the specified read-ahead cache tunable.
[-vserver <vserver name>]- Vserver-
If you use this parameter, the command displays the workloads that match the specified Vserver.
[-volume <volume name>]- Volume-
If you use this parameter, the command displays the workloads that match the specified volume.
[-qtree <qtree name>]- Qtree Name-
If you use this parameter, the command displays the workloads that match the specified Qtree name.
[-lun <text>]- LUN Name-
If you use this parameter, the command displays the workloads that match the specified LUN name.
[-file <text>]- File Path-
If you use this parameter, the command displays the workloads that match the specified file path.
[-max-throughput <qos_tput>]- Maximum Throughput-
Selects the workloads that match this parameter value
A maximum throughput limit specifies the throughput in IOPS that the workload must not exceed.
[-min-throughput <qos_tput>]- Minimum Throughput-
A minimum throughput specifies the desired performance level for a workload in IOPS.
[-is-adaptive {true|false}]- Adaptive-
If you use this parameter, the command displays only adaptive workloads.
[-is-constituent {true|false}]- Is Constituent Volume-
If this parameter is specified, the command displays information only about storage objects that either are or are not constituents of a FlexGroup, depending on the value provided.
cluster1::> qos workload show -class user-defined Workload Wid Policy Group Vserver Volume LUN Qtree File Path -------------- ----- ------------ -------- -------- ------ ------ ------------- vs2-wid100 100 pg1 vs2 - - - -
Shows all user-defined workloads and the corresponding storage objects on the "cluster1" cluster.
