storage aggregate efficiency show
Display aggregate storage efficiency details
The storage aggregate efficiency show command displays information about the different storage efficiency of all the aggregates.If no parameters are specified, the command displays the following information for all aggregates:
Aggregate
Node
Cross-vol-background-dedupe State (Enabled, Disabled)
Cross-vol-inline-dedupe State (Enabled, Disabled)
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-aggregate <aggregate name>]- Aggregate-
Displays the aggregate name. If this parameter is specified, the command displays detailed information about the storage efficiency of the specified aggregate.
[-node {<nodename>|local}]- Node-
Displays the node which owns the aggregate. If this parameter is specified, the command displays storage efficiency information only about the aggregates that are located on the specified node.
[-cross-volume-background-dedupe {true|false}]- Cross Volume Background Deduplication-
Displays whether the cross volume background deduplication is enabled/disabled in the aggregate.
[-cross-volume-inline-dedupe {true|false}]- Cross Volume Inline Deduplication-
Displays whether the cross volume inline deduplication is enabled/disabled in the aggregate.
[-cross-volume-dedupe-savings {true|false}]- Has Cross Volume Deduplication Savings-
Displays whether the aggregate has savings from cross volume deduplication.
The following example displays information about all aggregates that are owned by nodes in the local cluster:
cluster:::> storage aggregate efficiency show
Aggregate: aggr0
Node: vivek6-vsim2
Has Cross Volume Deduplication Savings: false
Cross Volume Background Deduplication: false
Cross Volume Inline Deduplication: false
Aggregate: aggr1
Node: vivek6-vsim2
Has Cross Volume Deduplication Savings: true
Cross Volume Background Deduplication: true
Cross Volume Inline Deduplication: true
2 entries were displayed.
