network port broadcast-domain show
Display layer 2 broadcast domain information
Display broadcast domain information.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-ipspace <IPspace>]- IPspace Name-
Selects the broadcast domains that match the IPspace name.
[-broadcast-domain <broadcast domain name>]- Layer 2 Broadcast Domain-
Selects the broadcast domains that match the broadcast domain name.
[-mtu <integer>]- Configured MTU-
Selects the broadcast domains that match the MTU value. This field is the MTU that was configured by the user, which might be different from the operational MTU.
[-ports [node>:<port],…]- Ports-
Selects the broadcast domains that contain the network ports. For example, node1:e0a will display broadcast domains that contain node1:e0a network port.
[-port-update-status {complete|in-progress|error|overridden-while-offline}]- Port Update Status-
Selects the broadcast domains that contain the network port status. For example, specifying "error" will display broadcast domains that contain "Error" network port status.
[-port-update-status-details <text>,…]- Status Detail Description-
Selects the broadcast domains that contain the network port status detail text.
[-port-update-status-combined {complete|in-progress|error|overridden-while-offline}]- Combined Port Update Status-
Selects the broadcast domains that contain the combined network port status. For example, specifying "error" will display broadcast domains that contain a combined network port status of "Error".
[-failover-groups <failover-group>,…]- Failover Groups-
Selects the broadcast domains that contain the failover groups.
[-subnet-names <subnet name>,…]- Subnet Names-
Selects the broadcast domains that contain the subnet name or names.
The following example displays general information about broadcast domains.
cluster1::> network port broadcast-domain show
IPspace Broadcast Update
Name Domain Name MTU Port List Status Details
Cluster Cluster 9000
node1:e0a complete
node1:e0b complete
Default Default 1500
node1:e0c complete
node1:e0d complete
2 entries were displayed.
