ONTAP commands
storage disk remove-reservation
Removes reservation from an array LUN marked as foreign.
The storage disk remove-reservation command removes persistent reservation from a specified foreign array LUN.
-disk <disk path name> - Disk Name (privilege: advanced)
This specifies the disk from which persistent reservation is to be removed.
The following example removes the persistent reservation from a disk named node1:switch01:port.126L1.
cluster1::> storage disk remove-reservation -disk node1:switch01:port.126L1
Looking for answers?
Try Doc, our Gen AI Assistant.
