vserver fpolicy policy external-engine delete
Delete an external engine
The vserver fpolicy policy external-engine delete command deletes an FPolicy external engine.
This command is not supported for a Vserver with Infinite Volume. |
-vserver <Vserver Name>- Vserver-
This parameter specifies the Vserver from which you want to delete an FPolicy external engine.
-engine-name <Engine name>- Engine-
This parameter specifies the name of the FPolicy external engine you want to delete.
The following example deletes an FPolicy external engine.
cluster1::> vserver fpolicy policy external-engine show -vserver vs1.example.com -engine-name new_engine
Vserver: vs1.example.com
Engine: new_engine
Primary FPolicy Servers: 1.1.1.1
Port Number of FPolicy Service: 10
Secondary FPolicy Servers: 2.2.2.2
External Engine Type: synchronous
SSL Option for External Communication: mutual-auth
FQDN or Custom Common Name: Sample1-FPolicy-Client
Serial Number: 8DDE112A114D1FBC
Certificate Authority: TASample1
cluster1::> vserver fpolicy policy external-engine delete -vserver vs1.example.com -engine-name new_engine
