storage tape show-errors
PDF of this doc site
Creating your file...
Display tape drive errors
The storage tape show-errors
command displays error information about tape drives attached to the cluster. By default, this command displays the following information about all tape drives:
Node to which the tape drive is attached
Device ID of the tape drive
Type of device(tape drive)
Description of the tape drive
Alias name of the tape drive
Tape drive errors
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
Displays detailed information about tape drives on the specified node.
[-device-id <text>]
- Device ID-
Selects the tape drive with the specified device ID.
[-device-type <text>]
- Device Type-
Selects the devices with the specified type of tape drive.
[-description <text>]
- Description-
Selects the tape drives with the specified description.
[-alias-name <text>]
- Alias Name-
Selects the tape drive with the specified alias name.
[-wwnn <text>]
- World Wide Node Name-
Selects the tape drives with the specified World Wide Node Name.
[-wwpn <text>]
- World Wide Port Name-
Selects the tape drive with the specified World Wide Port Name.
[-serial-number <text>]
- Serial Number-
Selects the tape drive with the specified serial number.
[-error <text>]
- Tape Drive Error Description-
Selects the tape drives with the specified error string.
[-initiator <text>]
- Initiator Port-
Selects the tape drives with the specified initiator port.
The following example shows error information for all tape drives attached to cluster1.
cluster1::> storage tape show-errors Node: node1 Device ID: 0d.125 Device Type: tape drive Description: Hewlett-Packard LTO-5 Alias: st0 Errors: hardware error; repair or replace tape drive Node: node1 Device ID: 2d.0 Device Type: tape drive Description: IBM LTO-6 ULT3580 Alias: st2 Errors: -
The following example shows error information for tape drive sw4:2.126L1 attached to the node, node1.
cluster1::> storage tape show-errors -device-id sw4:2.126L1 -node node1 Node: node1 Device ID: sw4:2.126L1 Device Type: tape drive Description: Hewlett-Packard LTO-3 Alias: st3 Errors: -
