system node external-cache show
Display external cache settings.
The system node external-cache show command displays external-cache information for each of the nodes available.
[-fields <fieldname>,…] -
Valid values for this option are
{node|is-enabled|is-rewarm-enabled|is-mbuf-inserts-enabled|pcs-size|is-hya-enabled}. Specifying the value will display all entries that correspond to it. - |
[-instance ]} -
This option does not need an input value. Specifying this option will display the information about all the entries.
[-node {<nodename>|local}]- Node-
Specify this parameter to display external-cache parameters that match the specified node.
[-is-enabled {true|false}]- Is Enabled-
Valid values for this option are true and false. Specifying the value will display all entries that correspond to it.
[-is-rewarm-enabled {true|false}]- Is rewarm on-
[-is-mbuf-inserts-enabled {true|false}]- Is Mbuf inserts on-
[-pcs-size <integer>]- PCS size-
Valid values for this option are integers between 16 and 16383. Specifying the value will display all entries that correspond to it.
[-is-hya-enabled {true|false}]- Is hya caching enabled-
cluster1::> system node external-cache show -node node1
Node: node1
Is Enabled: false
Is rewarm on: false
Is Mbuf inserts on: true
PCS size: 256
Is hya caching enabled: true
Displays the external-cache information about node1 in a list format.
