security session limit location show
Show per-location session limits
This command shows the per-location management session limits that have been configured for each interface and location.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-interface {cli|ontapi}]- Interface (privilege: advanced)
Selects the sessions that match this parameter value. This identifies the interface (CLI or ONTAPI) to which the limit applies.
- [-location <text>]- Location (privilege: advanced)
Selects the sessions that match this parameter value. This identifies the location for the limit. The limit with the location name -default-(only in theDefaultIPspace) is the limit used for any location (in any IPspace) without a specific configured limit.
- [-ipspace <IPspace>]- IPspace of Location (privilege: advanced)
Selects the sessions that match this parameter value. This identifies the IPspace of the client location. The default IPspace is Default.
- [-max-active-limit <integer>]- Max-Active Limit (privilege: advanced)
Selects the sessions that match this parameter value. This identifies the configured limit that is used to throttle or reject requests.
The following example illustrates displaying the per-location limits for management sessions.
cluster1::*> security session limit location show Interface Location IPspace Max-Active --------- -------------------- ----------- ---------- cli -default- Default 16 cli 10.98.16.164 Default 0 ontapi -default- Default 6 ontapi 10.98.16.164 Default 0 4 entries were displayed.
 PDFs
PDFs
