security session limit location show
Show per-location session limits
This command shows the per-location management session limits that have been configured for each interface and location.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-interface {cli|ontapi|rest}]
- Interface (privilege: advanced)-
Selects the sessions that match this parameter value. This identifies the interface (CLI, ONTAPI, or REST) to which the limit applies.
[-location <text>]
- Location (privilege: advanced)-
Selects the sessions that match this parameter value. This identifies the location for the limit. The limit with the location name
-default-
(only in theDefault
IPspace) is the limit used for any location (in any IPspace) without a specific configured limit. [-ipspace <IPspace>]
- IPspace of Location (privilege: advanced)-
Selects the sessions that match this parameter value. This identifies the IPspace of the client location. The default IPspace is
Default
. [-max-active-limit <integer>]
- Max-Active Limit (privilege: advanced)-
Selects the sessions that match this parameter value. This identifies the configured limit that is used to throttle or reject requests.
The following example illustrates displaying the per-location limits for management sessions.
cluster1::*> security session limit location show Interface Location IPspace Max-Active --------- -------------------- ----------- ---------- cli -default- Default 16 cli 10.98.16.164 Default 0 ontapi -default- Default 6 ontapi 10.98.16.164 Default 0 4 entries were displayed.
