Command reference
security session limit location show
Show per-location session limits
This command shows the per-location management session limits that have been configured for each interface and location.
[-fields <fieldname>,…​]
| [-instance ] (privilege: advanced) }
[-interface {cli|ontapi|rest}] - Interface (privilege: advanced)
Selects the sessions that match this parameter value. This identifies the interface (CLI, ONTAPI, or REST) to which the limit applies.
[-location <text>] - Location (privilege: advanced)
Selects the sessions that match this parameter value. This identifies the location for the limit. The limit with the location name -default- (only in the Default IPspace) is the limit used for any location (in any IPspace) without a specific configured limit.
[-ipspace <IPspace>] - IPspace of Location (privilege: advanced)
Selects the sessions that match this parameter value. This identifies the IPspace of the client location. The default IPspace is Default .
[-max-active-limit <integer>] - Max-Active Limit (privilege: advanced)
Selects the sessions that match this parameter value. This identifies the configured limit that is used to throttle or reject requests.
The following example illustrates displaying the per-location limits for management sessions.
cluster1::*> security session limit location show
Interface Location             IPspace     Max-Active
cli       -default-            Default             16
cli       10.98.16.164         Default              0
ontapi    -default-            Default              6
ontapi    10.98.16.164         Default              0
4 entries were displayed.
