vserver group-mapping swap
Exchange the positions of two group mappings
The vserver group-mapping swap command exchanges the positions of two group mappings in the priority list.
The vserver group-mapping swap command is not supported on Vservers with FlexVol volumes.
-vserver <vserver name>- Vserver-
This parameter specifies the Vserver on which the group mappings are located.
-direction {krb-unix|win-unix|unix-win}- Name Mapping Direction-
This parameter specifies the direction of the group mappings that you want to exchange. Each mapping direction (Kerberos-to-UNIX, Windows-to-UNIX, and UNIX-to-Windows) has its own priority list.
-position <integer>- Position-
This parameter specifies the position in the priority list of the first group mapping that you want to exchange. Specify a position as a positive integer.
-with-position <integer>- Position of an existing group mapping entry in the list of group mappings for this Vserver. This entry will be swapped with the entry at 'position'.-
This parameter specifies the position in the priority list of the second group mapping that you want to exchange. Specify a position as a positive integer.
The following example exchanges the positions of two group mappings on a Vserver named vs1. The group mappings have the direction Windows-to-UNIX. The group mappings are exchanged between positions 2 and 4.
cluster1::> vserver group-mapping swap -vserver vs1 -direction win-unix -position 2 -with-position 4
