network interface lif-weights show
PDF of this doc site
Creating your file...
Show the load-balancer LIF weights
The network interface lif-weights show
command displays the weights assigned to each LIF in a DNS load-balancing zone in a Vserver.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <vserver>]
- Vserver-
Use this parameter to display information only for the specified Vservers.
[-zone <text>]
- DNS Zone-
Use this parameter to display information only for the specified DNS zones.
[-address <IP Address>]
- Network Address-
Use this parameter to display information only for the specified IP addresses.
[-weight <double>]
- Load Balancer Weight-
Use this parameter to display information only for the specified load balancer weights
The following example displays LIF weights for vserver "vs1".
cluster1::> network interface lif-weights show -vserver vs1 Network Vserver DNS Zone Address Weight --------- ------------------ ------------ ------- vs1 a.com 4.4.4.4 12.4206 x.com 1.1.1.1 12.4206 x.com 10.72.46.236 12.4206 3 entries were displayed.
