system node internal-switch dump eeprom
Display onboard switch eeprom config
The system node internal-switch dump eeprom command is used to show the internal switch eeprom firmware content.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node <nodename>]- Node-
Use this parameter to specify the node the internal switch resides on.
[-switch-id <integer>]- Switch-
Use this parameter to specify the switch id. For example, 1.
[-version <text>]- Version-
Use this parameter to specify the version of firmware needs to be dumped.
[-eeprom <text>]- Firmware-
Use this parameter to specify the firmware content needs to be dumped.
The following example shows the internal switch eeprom firmware content of the internal switch 0 on Node1.
cluster1::> system node internal-switch dump eeprom -node Node1 -switch-id 0 EEPROM Configuration -------------------- Node: Node1 , Switch: 0 , Version: Version2 SB_XX Switch0 7fa300007fa900007fa800007fa700007fa610007fa5d0007fa200007fa30000 7fa610107fa802337fa713137fa5b0007fa200007fa300007fa610207fa80233 7fa731317fa5b0007fa200007fa300007fa610407fa802117fa733337fa5b000 8027102080282c808047101080482c808087102080882c808107101081082c80 8207104082082c808407104084082c8088082c808809000a880a80fa8024007c 7fe990007fea00047fe9bf017fea00047fe9b0007fea00197fe9b0017fea0020 7fe9b0027fea4c887fe9b0037fea01197fe9b0047feafff07fe9b0057fea00ff 7fe9b0067fea10007fe9b0078024007fffff56657273696f6e20320000005342 5f585800000053776974636820300000ffffffff0040e0e8100065b4100065b4 100065b42b2adfe00040586000000000000000012b2adfe0100087700040e0e8 000003b6000400087fc5e9a0000000001000877000000000000003b600040008 10008770100014682b2adfe00000000010001050000000017fc5e9a010001468 2ab094700040e0e8100065b4100065b42b2adfe0004059bc000000c0100018e8 7fc5e9d80040c01800000000000000c000000026000000001000877000000000 000003b6000e001c10008770000000010000001e0000001e2ab094700040e0e8 7fc5ea180040491000000000000000060041bc2c7fc5
