ONTAP commands
vserver security trace filter show
Display a security trace entry
The vserver security trace filter show command displays information about security trace filter entries. Prior to Data ONTAP 9.3, this feature was only supported for CIFS. In Data ONTAP 9.3 and later, this feature is supported for both NFS and CIFS.
NFS security trace filters are not supported for FlexGroup volumes, and will only be applied to the FlexVol volumes within the specified Vserver.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver
If you specify this parameter, the command displays permission tracing information only for filters applied to the specified Vserver.
[-index <integer>] - Filter Index
If you specify this parameter, the command displays permission tracing information only for filters with the specified filter index number.
[-protocols {cifs|nfs}] - Protocols
If you specify this parameter, the command displays permission tracing information only for filters applied to the specified protocols.
[-client-ip <IP Address>] - Client IP Address to Match
If you specify this parameter, the command displays permission tracing information only for filters applied to the specified client IP address.
[-path <TextNoCase>] - Path
If you specify this parameter, the command displays permission tracing information only for filters applied to the specified path.
[-windows-name <TextNoCase>] - Windows User Name
If you specify this parameter, the command displays permission tracing information only for filters applied to the specified Windows user name.
[-unix-name <TextNoCase>] - UNIX User Name or User ID
If you specify this parameter, the command displays permission tracing information only for filters applied to the specified UNIX user name or user ID(for NFS specififc filters).
[-trace-allow {yes|no}] - Trace Allow Events
If you specify this parameter, the command displays information only about events that either trace or do not trace allow events, depending on the value provided.
[-enabled {enabled|disabled}] - Filter Enabled
If you specify this parameter, the command displays information only about filters that either are enabled or disabled, depending on the value provided.
[-time-enabled <integer>] - Minutes Filter is Enabled
If you specify this parameter, the command displays information about the time durations configured for filters during creation.
The following example displays security trace filters for Vserver vserver1 .
cluster1::> vserver security trace filter show
Vserver  Index   Client-IP     Path          Trace-Allow Windows-Name  Protocol
vserver1 1     -            -                no          domain\user   cifs
vserver1 2     192.168.2.3  -                yes         -             cifs
vserver1 3     -            /dir1/dir2/file  no          domain\       cifs
                                                         administrator
vserver1 4     -            file             yes         -             nfs
4 entries were displayed.
