volume efficiency policy delete
Delete an efficiency policy
The volume efficiency policy delete
command deletes an efficiency policy. An efficiency policy can be deleted only when it is not associated with any volume. The pre-defined policies default
and inline-only
cannot be deleted.
-vserver <vserver name>
- Vserver-
This specifies the Vserver on which the volume is located.
-policy <text>
- Efficiency Policy Name-
This specifies the policy name.
The following example deletes an efficiency policy:
cluster1::> volume efficiency policy delete -vserver vs1 -policy policy1
