vserver vscan connection-status show
Display Vscan servers connection status summary
The vserver vscan connection-status show
command displays connection status summary of the external virus-scanning servers, or "Vscan servers" for a Vserver. If you do not specify any parameters, the command displays the following information for all Vservers:
Vserver name
Node name
List of connected Vscan servers
Connected count
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
If you specify this parameter, the command displays information only about the Vscan servers attached to the specified node.
[-vserver <vserver name>]
- Vserver-
If you specify this parameter, the command displays information only about the Vscan servers for the specified Vserver.
[-servers <IP Address>,…]
- List of Connected Vscan Servers-
If you specify this parameter, the command displays information only about the Vservers that have the specified server or servers.
[-connection-count <integer>]
- Number of Connected Vscan Servers Serving the Vserver-
If you specify this parameter, the command displays information only about the Vservers that have the specified connection count.
The following example displays connection-status summary for all Vservers.
cluster1::> vserver vscan connection-status show Connected Connected Vserver Node Server-Count Servers --------------- ------------------- ------------ ----------------------------- vs1 Cluster-01 2 1.1.1.1, 2.2.2.2 vs2 Cluster-01 0 - 2 entries were displayed.
